0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 3 New Guy | | New Guy Joined: May 2015 Posts: 3 | Gentlemen, I'm new to the forum so forgive me if I missed this topic elsewhere. My 1971 350 has a casting # 3970010....it's a 350. BUT, the flat spot on the block in front of the passenger head is stamped 9.015 period. This engine was worked on 20 years ago by Pettis Performance in Hesperia but they haven't responded to requests for info. Is this "9.015" a factory number or maybe a mod number the shop put on it after grinding off the original?? or I am I looking in the wrong place??
Thanks for any help | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Bigwire, all the engine serial numbers I've seen were alphanumeric, two or three letters followed by numbers, hope that helps. | | | | | Joined: May 2015 Posts: 3 New Guy | | New Guy Joined: May 2015 Posts: 3 | That's what puzzles me. The area depicted in other posts usually has the alpha numeric string. Mine only says 9.015.
The date code is B 4 7. That must mean its a '77?
Thanks 3B! | | | | | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | I'll take a guess the 9.015 refers to the deck height. Stock deck height on a small block is 9.025. They probably took a .010 cut on the decks to true them up. This would have removed the original stamping which was re-stamped with the new deck height of 9.015. It's a guess, but seems logical.
John | | | | | Joined: May 2015 Posts: 3 New Guy | | New Guy Joined: May 2015 Posts: 3 | John, thanks! I think you are absolutely right. It makes complete sense now. I appreciate your time.
Tom | | |
