1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 52 Member | | Member Joined: Jun 2000 Posts: 52 | Can anyone email a pic of a 47-53 (ideally a 50) with rear bumper guards CORRECTLY installed? Searched the gallery, none to be found! Please HELP! | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Wouldn't it be the same as front guards, though I can't say I've ever seen rear guards.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I had rear bumper guards on my '51 Chevy pick up. They were installed in the same manner as on the front, by removing the second bumper bolt from each end ,then bolting up the guards,in these holes. | | | | | Joined: Jun 2000 Posts: 52 Member | | Member Joined: Jun 2000 Posts: 52 | Thanks...I've been warned now that with these on the rear, if I'm not careful I'll dent my tailgate! Did you have that problem? Otherwise, I'll just put em in front! | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Did not have that problem with mine. After hooking tailgate chains I still had clearance. | | |
