| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | I've rebuilt a 1952 Chevy 216. Two questions: (1) Would it be good to use synthetic oil (Mobil - which I understand is a synthetic/regular oil mix)? If yes, how many miles should I wait in using the synthetic oil, to let everything seat-in (with regular oil)? (2)If "no" to the above, is it now okay for me to use regular detergent oil, vrs. non-detergent? Thanks. Bob | | | | | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | Opinions about oil on this site are like - - - -uh- - - -"noses". Everybody's got one and some of them are pretty smelly! My personal opinion is that a straight-weight high detergent mineral oil like 20 or 30 weight would be my first choice, followed by a 15W-30 Diesel rated oil if there was some reason to run a multi-grade. The clearances in stovebolt engines do not seem to work well with very low-viscosity oils like 5W-30, etc. I don't know of any oil manufacturer that sells a straight-weight synthetic.
Duck and cover- - - -let the flaming begin! Jerry
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | The old things ran a long time on single weight oil. I still believe in breaking them in on a 20 weight non detergent, but it is hard to find. A single weight oil would be my second choice and it is still available. I always add ZDDP to any engine with flat tappets. Once they are broken in, Mobil one makes a high mileage oil. https://mobiloil.com/en/motor-oils/mobil-1/mobil-1-high-mileageIt seems to work quite well in old engines and extends the drain intervals a lot. I am hesitant to recommend a Diesel oil because Diesel generates different contaminants than a gasoline engines. But that doesn't keep a lot of guys from using Rotella 15W40. Like Jerry says, this is a very controversial subject. I think everyone will agree that you don't want a synthetic designed for modern cars. | | | | | Joined: Feb 2014 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2014 Posts: 48 | In my 54 car and my old 235 I ran straight 30 Rotella. The motor was old and tired, so I'm sure it was just happy to have any oil. I used rotella based on recommendation because of the slightly higher zinc levels. It could all be b.s. for all I know. I just replaced that motor with a rebuilt 235 that I got from Tom Langdon. He recommended using any regular 5w-30 or 10w-30 motor oil. I opted to go with Brad Penn 10w-30 motor oil. Is it necessary, I don't know, but the price isn't much different so I figure it's also not going to hurt. Just my 2 cents. To each their own, but I would stay away from the synthetic.
Matt Blacktop Cannibals Car Club 1954 Chevy mild custom car 1955 Chevy second series 3200
| | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | I run 15/40 rotella in every vehicle i own. From my 1942 chevy, to my wifes 2006 4-runner, no problems in any. | | |
