3 members (TexasA&M48Truck, TUTS 59, Stovebolt48), 62 guests, and 8 robots.
Topics128,021
Posts1,055,348
Members48,420
#1103198 05/17/2015 2:39 AM
235 with the stock single barrel carb and setup.
I've got this project to the point where I can fire up the engine, and the good news is, it runs. But...
At the first attempt it would run for 1 second and then die. Also, gas leaked out of both the upper and lower gasket on the front side of the carb. I opened it up and reset the float to the spec 1 3/4" (it was off by about 1/8") and that gave me some improvement. Now it will continue to run but at a very high rpm even with throttle knob all the way in. The longer it runs the faster it goes. Also, I still have gas coming out of both gaskets.
Should I continue to reduce float drop? Should I have used gasket sealer?
thanks.
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
whatever you do, do NOT use gasket sealer
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Sounds like your float needle isn't seating properly. Could be from trash in the bowl.
Carl
Rebuilt the carb, so the needle is new and the body clean. That's part of what has me scratching my head.
Just because a part is new doesn't mean it can't be defective. I'd make sure that nothing is hanging up and recheck the float that its moving up and down smooth.
