8 members (Hotrod Lincoln, 2-Ton, DadsFirstPickup, Otto Skorzeny, HandyAndy, Peggy M, DES57, Jman),
124
Mod | | | Forums66 Topics128,102 Posts1,056,532 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | Current sealed head lamps are just plain bad. Would like to put something better in but I don't want to add any wiring (as I'm told is needed for HID lamps). Any recommendations on headlamps? I have high and low beams and only one headlight per side. (Not duals) I'm getting ready to install a new wiring harness with new switches as well.
Thanks in advance.
1955 GMC 100 Series 2
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | You think you got it bad. My ride has 15 candlepower headlights. You can hardly read a newspaper at night six inches from them. Seriously, it all about watts. P(watts)= I(amps) X E(voltage). Your voltage is constant, so the only thing you can change is amps to get more watts(brighter lights). Have you thought about a relay. The run of the mill relay costs less than five bucks. It's good for 30 amps. A few feet of heavy wire #10 inside the engine deck with the feed wire from your light switch to energize the relay and you got it. Good luck.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I run halogen sealed beams on my '54 and my '56 without relays. They are noticeably brighter than standard sealed beams. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I've been using the Silverstar bulbs from Sylvania, they give a cleaner light output over a standard halogen. either will work fine without having to rewire the headlamps. Your truck will take a 6024 bulb.
Bill Burmeister | | |
