1 members (Phak1),
186
Mod | | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I spent the weekend designing a door addon for the SuperJig. This allows you to go from sandblasting to sanding and final topcoats with one jig. When you need to get to the hinge screw area, just take the screws out temporarily without moving anything. The door addon is near the bottom of the article here: http://devestechnet.com/Home/SuperJigPlans | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Turns out I have no complaints about this setup in longboarding and sanding every square inch of the two doors by hand. Every square inch of the entire truck gets sanded three times using three different grits, so I really appreciate when something doesn't move while pushing and pulling hand sanders across the parts. With the doors out of the way, the next setup that needs to be engineered will be for the fenders.
This SuperJig is awesome, but not for a guy doing a frame up restoration of ONE truck. Its mostly for people thinking they will do a few more. It took me a few days to engineer the door setup and it takes about 4 days per grit to sand both doors. It will be a real time saver on the next set of doors for sure.
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Pretty slick solution Deve.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Apr 2010 Posts: 123 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 123 |
Chuck
1950 Chevy 3100 Deluxe Cab A few Harleys and '76 Triumph Bonneville
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | I recently got a chance to see the Super Jig and it is jaw dropping awesome!!! | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Wish you could have stayed longer. It was lot of fun!
| | | | | Joined: Aug 2015 Posts: 12 New Guy | | New Guy Joined: Aug 2015 Posts: 12 | Very nice. I work harder fighting the panel as doing the work. Must Have | | |
