2 members (2-Ton, farmallb),
67
Mod | | | Forums66 Topics128,021 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2003 Posts: 68 | Will a minute fraction of an inch less off the original glass width effect the seating of the glass in the windshield weatherstripping after installed on the truck? Is a little thinner glass better than thicker glass. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I had no problem getting new glass that was the same thickness as my original. There is enough give in the gasket that you can probably go either way a bit.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Careful! if the new glass is slightly larger and you are trying to put back in the stainless molding around the window frame, you may have a really hard time getting it back it. My glass was a little larger and I never got the rubber and molding back in. Will try to tackle it again next winter in the garage. | | |
