5 members (UtahYork, Bucker, Buckeye998, Stovebolt48, Hotrod Lincoln), 152 guests, and 2 robots.
Topics128,190
Posts1,057,339
Members48,469
#110231 11/20/2004 1:23 AM
Junior Member
Junior Member
I'm working on prepping the inside of my cab for paint and would like to remove the dash. I've removed all the instrumnents, controls, glove box, etc. from the dash. There are 3 bolts on each side of the dash that attach it to the side of the truck that I have removed. Finally there are 2 bolts that attach it to the steering column that I have removed. There doesn't appear to be any sort of attachment along the front (under/along the winshield.) The ends where I removed the bolts will flex, but I cannot pull it out. Is it welded in there? I have the shop manual but haven't seen anything on removal of the dash in it.
Isaac
#110232 11/20/2004 5:16 AM
Leave it in there, it has about 100 spot welds under the windshield rubber holding it in place. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#110233 11/20/2004 12:52 PM
Junior Member
Junior Member
