0 members (), 311 guests, and 5 robots.
Topics128,162
Posts1,057,042
Members48,463
#1102132 05/11/2015 10:10 PM
MFW
Offline
I have a 1954 chevy 3100. The truck is a 235 equipped with the hydra-matic trans. I was told by a gentlemen that the gear ratio was different then trucks with the standard transmission. Is this true? Thanks
MFW
1950 GMC 100
1954 GMC 470
1954 Chevy 3100 Hydramatic
More pix on Flickr
1957 Ford 850 Tractor (video)
The final drive (4th speed) gear ratio is the same as the 3-speed and the 4-speed manual transmissions: 1:1 in high gear
The ratios of gears 1-4 are different between the H-M and the 4-speed manual transmission.
Reverse gear ratios are different in all the transmissions.
1954 truck manual transmission ratios (forward and reverse)
1954 truck Hydra-Matic transmission ratios (forward and reverse)
MFW
Offline
Ok,cool thanks. What about the rear end? Same as standard ?
MFW
1950 GMC 100
1954 GMC 470
More pix on Flickr
The H-M rear end ratio is 3.90:1 , as used in other 1954 1/2 ton trucks.
HOWEVER: the H-M torque-tube is a shorter length - so, the H-M rear-end is NOT interchangeable with the manual tranmissions' rear torque-tube.
H-M and Manual trans. torque tube measurements.
Torque tube length and how to measure.
Torque tube length
1948-54 Manual trans. 60 1/8" , 3 and 4 speed tranny's
1954---- H-M trans.....53 7/8"
Propeller shafts are different lengths. Type C
1948-54 Manual trans. 63 7/8"
1954---- H-M trans. 57 5/8"
Splines are the same on both. 17
SOURCE
I think that is the only difference between the H-M and Manual trans. torque tubes
Torque tube length (and, Propeller shafts) are different lengths. .
That is correct.
We converted a 1954 3100 H-M rear-end to 3.55 Ring & Pinion, using the standard installation/seal/bushing kit.
