| | | Forums66 Topics128,162 Posts1,057,066 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 109 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 109 | I have a 1954 chevy 3100. The truck is a 235 equipped with the hydra-matic trans. I was told by a gentlemen that the gear ratio was different then trucks with the standard transmission. Is this true? Thanks
MFW | | | | | Joined: Oct 2012 Posts: 109 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 109 | Ok,cool thanks. What about the rear end? Same as standard ?
MFW | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The H-M rear end ratio is 3.90:1 , as used in other 1954 1/2 ton trucks.
HOWEVER: the H-M torque-tube is a shorter length - so, the H-M rear-end is NOT interchangeable with the manual tranmissions' rear torque-tube.
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | H-M and Manual trans. torque tube measurements. Torque tube length and how to measure. Torque tube length1948-54 Manual trans. 60 1/8" , 3 and 4 speed tranny's 1954---- H-M trans..... 53 7/8" Propeller shafts are different lengths. Type C 1948-54 Manual trans. 63 7/8" 1954---- H-M trans. 57 5/8" Splines are the same on both. 17 SOURCE I think that is the only difference between the H-M and Manual trans. torque tubes | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | H-M and Manual trans. torque tube measurements. . Torque tube length (and, Propeller shafts) are different lengths. . . I think that is the only difference between the H-M and Manual trans. torque tubes That is correct. We converted a 1954 3100 H-M rear-end to 3.55 Ring & Pinion, using the standard installation/seal/bushing kit. | | |
