2 members (ShopRag, DaveV), 97 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
#1101943 05/10/2015 11:36 PM
just found out that my ranco valve, when on leaks, So Iam going to put in a manual shut off valve,which is better, one you control with a cable from inside or one that you have to open the hood to open. 53 3100 root
root #1101964 05/11/2015 1:40 AM
Type in "cable operated heater control valve" and you will find
a hundred of them. Stick it in one of the heater lines, hang
the cable knob under the dash and be done with it.
dg
Denny G
Sandwich, IL
root #1102071 05/11/2015 4:20 PM
Leaks by , or leaks fluid into the cab or compartment.
root #1102086 05/11/2015 5:32 PM
Leaks fluid into cab 53 3100 root
root #1102091 05/11/2015 6:20 PM
The seal can be replace for about $10, but....it's a one time
shot cuz you have to bend the four tabs to disassemble it. If
it's already been opened up then there is a very good chance
that you will break off one or more of the tabs. It's also
difficult to get the two pieces back together tightly when
bending the tabs back down.
This series of pictures might help to discourage you from
rebuilding the Ranco valve and encourage you to install an
inline shut off.
http://www.pbase.com/dennygraham/ranco_hf_br&page=all
dg
Denny G
Sandwich, IL
root #1102206 05/12/2015 3:16 AM
Sounds like a inline shutoff valve is in order. Denny thanks for the pictures and input. 53 3100 root
