Brrrr
place holder
5 members (Shade Baby, ShopRag, Hugh63c10, dt235sd, Perro), 85 guests, and 2 robots.
Topics128,271
Posts1,058,417
Members48,485
Did the 1 1/2 ton stake bed come with parking lights and turn signals? I am studying the wire diagram and it shows only one.
Andy
Sometimes you're the window
Sometimes you're the bug
3B Offline
Hy TK421, as far as I know turn signals were an accessory, you could get them installed by the dealer before you accepted delivery of your new truck, but they were not part of the factory harness, hope that helps.
Turn signals were not standard equipment until late '50s.
1954 was the first year that factory option/installed turn-signals were available.
As 3B posted, accessory turn signals were available prior to 1954 (GM and other units installed by dealer, by owner, by shop, or by friend/relative).
As 3B posted, the factory wiring diagram did not show signal wiring. The wiring was specific to the accessory unit that was purchased.
Even duel tail lights were an option.
