1 members (stlcardinalsguy),
115
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | So, brakes are done, rear end is sealed up ...it seems like it's driving ok. It's far from done, lots of little details, but I'm pretty excited. I took it down to the park last night and took some pictures: http://flic.kr/p/rwkwQ3 | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Nice truck Dawg! I love your paint job too by the way! | | | | | Joined: Feb 2013 Posts: 614 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 614 | Nice job on your end! From were it came from to now, WOW! Nice rims, what are they?? Looking to update my wheels and tires! | | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | The rears came with it. They're the 1 piece 19.5s. The fronts are off of a '84 3/4 ton Suburban. I have to use spacers, 2 washers per lug, so that the drums don't rub on the tie rods, but they work great otherwise. I also had to modify them to get the hubcaps to fit, that was a pain.
Good luck with yours! | | | | | Joined: Feb 2013 Posts: 614 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 614 | It might have been a pain but it looks great! Nice job. What size were they? You got me thinking! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | ...The fronts are off of a '84 3/4 ton Suburban. I have to use spacers, 2 washers per lug, so that the drums don't rub on the tie rods, but they work great otherwise... The thought of using washers as wheel spacers concerns me. If you need a thin spacer then consider making or purchasing them as a plate with all the appropriate holes in them. Most single wheels have the center where the bolt pattern is stamped such that the wheel is only contacting the hub or drum at the outer edge and in the center, not right at the stud. Even if the wheel is flat and a washers seem to fit well as spacers I don't think it is as secure as having good contact all over the wheel mounting surface, and particularly at the outer edge. If the wheel is only making contact with the hub right at the studs they may not be strong enough for the extra leverage imposed on them. Other ways of getting more suitable spacers are to machine all but the flat plate off a drum or rotor. Or cut the center out of a spare wheel, dually wheels usually have plain flat centers good for this. Grigg | | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yes, that's the idea. I'd find some with only 8 holes, not the dual pattern type. If you can scrounge a drum, disc, or dual type wheel with your bolt pattern and have access to a lathe you can make some pretty nice spacers. | | | | | Joined: Jan 2015 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 48 | What a great truck. Here's to the one tons! | | | | | Joined: Nov 2012 Posts: 444 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 444 | Love the truck. It begs to tell a story just the way it sits. Please keep posting photos. I am restoring a 3800 that was my grandfather's and changing parts on another 3800 to create a weekend driver. It looks JUST LIKE your GMC. I'm about 2 weeks away from getting my brakes to look like yours. My NAPA guy can't find brake hoses from the wheel cylinders to the frame. HE's a nice old guy but I wish he would let me use his catalogs. Best - Joe 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Find a good parts store. They can make brake hoses in minutes.
Also check the vendors links on the home page. They sell brake hoses for my 1946 2 ton so I'm sure they have them for your truck. | | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | Glad to see yours on the road! Very cool truck...btw, your video of the rear brakes helped me get mine done & on the road today as a matter of fact....Thanks!!! | | | | | Joined: Nov 2012 Posts: 444 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 444 | RDQ (Really Dumb Question) - My dually has 18" 3=piece split rims. I guess Coker tire has them.....But those 19.5's look great. Do you know what the 19.5's were off of ? I'm searching far and wide coming up empty. 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Single and dual 19.5's are out there, some early ones may or may not clear tie rod ends, calipers, check first. Bread vans, etc.
| | | | | Joined: Feb 2012 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 112 | There is a set of 19.5 singles on ebay for $1500, and a set of 17.5 8 bolts for $500... The prices keeps going up but $1500 is outrageous in my opinion.. Dually 19.5 are much more common and see those on ebay and craiglist all the time.
I have a set of 19.5 singles on my 1 ton and the tires are approx 34" tall... Helped a little with increasing cruising speed but not much.. But with 5:14's and 45-50 mph top end every little bit helps!
Old Truck addict 1950 chevy 1 ton napco 1956 gmc 1 ton dually napco 1954 chevy 3/4 ton napco 1957 gmc civil defense napco panel
| | | | | Joined: Nov 2012 Posts: 444 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 444 | I'm on a hunt. I'm going to carry a brake drum with me to the junk yards. If I could get a rim to go around a rear drum I'm golden. But no way would I pay $1500 for 6 rims..... 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | |
