7 members (Joe H, JW51, Millenimech, dt235sd, Eisenholtz, klhansen, Ponchogl), 109 guests, and 0 robots.
Topics128,051
Posts1,055,764
#1101691 05/09/2015 7:02 AM
Does anyone know which mounting base gasket to use on a one battle carb on a 235 motor the kit came with two. I have a 53 Chevy truck it has a later model 235 motor . There's two different gaskets . Does anyone have a pic of the correct gasket to use on this application ? Thxs
sal moreno #1101700 05/09/2015 1:04 PM
You need to use the gasket that has the slots on the inside of the circle.
sal moreno #1101702 05/09/2015 1:20 PM
sal moreno #1101714 05/09/2015 3:44 PM
Make sure the slots are in the same position as in Tim's link.
The ones in most gasket kits are wrong for most carbs and cover the power valve vacuum port.
My Blog
Pre '68 Dave #1101773 05/09/2015 11:06 PM
What happens if the power valve vacuum port gets covered up ?
sal moreno #1101774 05/09/2015 11:07 PM
The carb runs VERY rich all the time.
