| | | Forums66 Topics128,188 Posts1,057,220 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | just tuning the 235 1959 after cheapo rebuild new rings hand seat valves. the bore had checked out good. anyway when first start up before it warms up it runs great idles good. after warms up a little it wont idle at original setting and runs rougher. i am running without thermostat so not warming up to much. any ideas ?? thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy rwb, firstly why no thermostat, the thermostat helps to bring the engine up to operating temperature quickly and helps to preserve the oil and prevent excess wear. I assume when you first start it there is some choke involved, does it start to run roughly once the choke is all the way off? | | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | i was running without thermo just to eliminate making sure wasnt going to heat up for check out.it runs really good idles ect until gets a little warm then wont idle. if i leave it alone start later same thing runs good at start up for about 5 mimutes drive a lttle runs bad. i am running gas straight out of bottle container. new coil and condensor.thanks
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy rwb, before the rebuild how did the engine run? | | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | it wasnt running sitting in a field at least 20 years rings all carboned up. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy rwb, seeing as how we have no clue how the engine ran I would say a complete check and repair of all components is in order, carburetor, distributor, spark plugs, spark plug wires. If you could put a vacuum gauge on the engine and record and describe the readings for us we may be able to offer suggestions. My first thought is carburetor issues or a vacuum leak, hope that helps. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Reset the valves when the engine heats up,maybe they are set to tight.I set them with an extra 2 thou. when I first start an engine just to make sure it will run OK.After I get the timing set and the carb adjusted I'll go back and reset the valves when the engine is at temp.Get that thermostat in so you can get to operating temp.
Pete | | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | i had the exact same issue after i rebuilt my 56 235
engine started REALLY easy without choke when cold and ran fine but once warmed up it would stall on idle (but ran fine otherwise)
i fixed it. the solution was either the fitting of a new coil (old one caught fire) or tuning of the carb idle valve. my money is on the carb tuning but cant say for sure as i changed both simultaneously
i tuned the carb by buying a cheap tachometer and using that to monitor the rpm wile adjusting the idle screw together with the idle fuel adjuster, engine warm. i managed to set the idle at the correct value circa 500rpm with the idle fuel valve adjusted so that any tigher drops the rpm and any losser has no effect. in other words i minimised the idle fuel metering to match idle fuel needs (at 500 rpm)
it solved the problem so my best guess is i had too much fuel at idle which was good when cold with no choke but bad when warm.
i think the idle fuel valve and idle speed needs to be set on a warm engine - when cold you use the choke to adjust. in my case the engine was set so it could run fine cold without choke...which was fine until it was hot then stall on idle
ymmv
