1 members (UtahYork),
88
Mod | | | Forums66 Topics128,142 Posts1,056,491 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Did the 1 1/2 ton stake bed come with parking lights and turn signals? I am studying the wire diagram and it shows only one.
Thanks Andy
Sometimes you're the window Sometimes you're the bug
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy TK421, as far as I know turn signals were an accessory, you could get them installed by the dealer before you accepted delivery of your new truck, but they were not part of the factory harness, hope that helps. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Turn signals were not standard equipment until late '50s.
1954 was the first year that factory option/installed turn-signals were available.
As 3B posted, accessory turn signals were available prior to 1954 (GM and other units installed by dealer, by owner, by shop, or by friend/relative).
As 3B posted, the factory wiring diagram did not show signal wiring. The wiring was specific to the accessory unit that was purchased. | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Even duel tail lights were an option. | | |
