3 members (3B, Lonnie, klhansen),
60
Mod | | | Forums66 Topics128,186 Posts1,057,315 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | My truck is being restored and I am thinking about moving the spare from under the bed to the side. Other than installing a fender with the cut-out and the correct hanger, what other modifications are necessary? How does the hanger mount? Thanks.
1965 Chevy C20 Stepside
| | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | Thanks so much John. My truck is a long bed restoration. In the photo of the installed hanger I don't see the angle iron brackets. Am I correct to assume that one mounts on the outside of the bed and the other on the inside? Thanks again. Rob
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Rob, The angle iron brackets attach to the outside of the bed.John | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | Thanks for the photos John. Rob
| | | | | Joined: Mar 2008 Posts: 7 New Guy | | New Guy Joined: Mar 2008 Posts: 7 | On my 64 the spare is down low in front of the right fender, in that space I think it looks nice tucked away. It sits on the step and on top the tire is about an inch above the bed rail. | | | | | Joined: Oct 2011 Posts: 20 New Guy | | New Guy Joined: Oct 2011 Posts: 20 | I have a 63 1/2 ton 4x4 stepside with the factory spare on the left fender. I decided it would look interesting to have one on the right also. Just copied dimentions from one side to the other, cut it out with a 1 in lip to bend at 90 deg. and filled with fiberglass. Fabricated supports, angles and tire mount. Turned out pretty good. I'd send pictures if I could figure out how to attach pictures. Be happy to send them directly to you. | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | Jim, is your spare a stock or custom installation? Rob
| | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | Is there a difference between the short-bed and the long-bed spare tire brackets? Is it the same bracket, just mounted differently?
| | | | | Joined: Mar 2008 Posts: 7 New Guy | | New Guy Joined: Mar 2008 Posts: 7 | First week of April I can take the spare off and take a couple of pics. to figure it out if you want. Here's an over view https://www.flickr.com/photos/77478750@N05/16099351693/in/set-72157651179443285 I think Hotrodjohn had some pics. of how the scooped out section in the fender were at a different height for 6' and 8' beds. It's not so much where the bracket is mounted the fenders are different. | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | I think I have figured it out now and I have found the right fender and bracket. Thanks anyway Jim.
| | | | | Joined: Apr 2014 Posts: 62 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 62 | Cape65
I wouldn't make that conversion. IMO and all due respect too all side mount owners but I think the under mount leaves a truck with a cleaner look.
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years) 1966 Chevelle (owned 53 years) | | | | | Joined: Jan 2014 Posts: 86 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 86 | I'd follow through with the side mount conversion. While admittedly they do not have a cleaner look as mentioned by jb66ss396, they sure do add character.
Bob
1959 Chevy Apache Short Bed Step Side 1967 Cadillac DeVille Convertible 1967 Pontiac Firebird Convertible
| | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | I do agree that the under bed mount is cleaner but I want the character look as Bob mentioned. Besides, I wasn't able to find a good OEM DS fender without the spare tire cut-out. Go figure!
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | It's all a personal preference thing... there are features to these trucks that are unique and the side mount spare certainly qualifies. It's my favorite feature of a step side, a feature from days gone by.
Not to mention it is very handy, for changing out a flat and for making sure the spare tire is inflated. | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | It will be alot more handy in case of a flat. It is like bench pressing to get the spare in or out from under the bed. I'm not as young as I once was!
