7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible),
85
Mod | | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I got the new garage built and I'm starting on getting my 52-3100 to a hot rod.
On the front brake from drum to disc conversion I found two units one is sold by SSBC #A148-15 secound one is sold by CCP #4759WBK5
what do you guys think is the better one?
Thanks,Pete | | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | I can't compare the two, but I can say I installed the CPP without any issues. | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | try speedway motors,beets most venders.i folloed instructions,installation was quick and simple. | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | I used Speedway motors, bets price and had not problems installing them. Make sure you get the ones for the truck and not the car, the spindles are different. 53 3100 root | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Looks like you are pricing the 5 lug without booster. It seems like the Summit CPP price ($375) with free ship beats the SSBC. One has hoses other has the pads. Hoses are more expensive. Both have cast iron GM calipers and probably do not include the slotted rotors shown. Both seem to include the roller bearings which you need. POL has more stuff included, cheaper price and free ship: http://www.ebay.com/itm/1947-55-54-...22380736?hash=item257dae8ac0&vxp=mtrI have found many times that these "trusted" type vendors have good specials on EBAY. I AM NOT SAYING THIS LINK IS TO A PRODUCT THAT FITS YOUR TRUCK. That's up to you. Some people have trouble with wheels fitting these kits. I have not have any trouble. You can easily and safely grind off the caliper sometimes. If you have a 16" or larger wheel you will probably be OK. Many 15" will work. But they do warn you in the literature/ads.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Thanks,I never heard of POL but I think that will be the one.I'll also check on speedway and see.
Thanks again,Pete | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | It's Performance OnLine. I have purchased from them as well as the others you mention. You can find good and bad experiences about all of them. Summit and Jeggs and others just drop ship from the same supplier. Most of those kits have the same parts.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The CPP and the POL kits are different. I have used one of each. I had to do some custom fitting on them both. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Looks like Speedway is the one at 250 they have the best price and they include hoses and pads.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I'm going to call them today and see what the shipping is I was thinking the same thing.
Pete | | |
