| | | Forums66 Topics128,047 Posts1,055,662 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 51 | Anyone know where to buy these rear leaf spring hangers do any vendors sell them or are they parts wanted section. Mine is busted and farmer rigged it's on 51 chevy 4400 I would take it off my other truck but would like to keep both trucks rolling as they are in two different locations. [IMG]http://i830.photobucket.com/albums/zz228/jhchevy51/20130904_110247_zps9dd95690.jpg[/IMG]
1947.5 Chevy 4100 red primer 1951 Chevy 4400 grey primer
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Can you post a photo of what you want to replace? Are you referring to shackles or the hanger attached to the frame? You could try calling Eaton Detroit Spring (for the shackle). http://www.eatondetroitspring.com | | | | | Joined: May 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 51 | The hanger that attaches to frame with riviots
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good luck finding a new one. Place a want-ad in the Swap Meet. You might want to try to find the part in the Master Parts Catalog, so you can post what size trucks and year trucks used the same parts. http://chevy.oldcarmanualproject.com/parts/1929_54/index.htm | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I had a broken hanger on my 3/4 ton. The entire bottom was broken with nothing holding the spring. I had a machine shop rebuild. Pictures here. Hope this helps. Good luck and have fun Dan | | | | | Joined: Apr 2012 Posts: 35 New Guy | | New Guy Joined: Apr 2012 Posts: 35 | I would almost bet they are the same as the 3/4ton & 1 ton because the 3/4 & 1 ton use the same mounts & they also use a spacer that is about 1/2in wide so the clevis doesn't move side to side. The 4400 springs are 2.5" wide & the 3/4 & 1ton springs are 2" wide. Remove the space they use w/the clevis & you should be able to use that mount with your springs.
An elephant is a mouse built to government specifications.
| | | | | Joined: May 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 51 | Looked at the oldcarmanual could only find listing for 1/2 ton trucks and pass not sure if I looked in the right spot but that thing is hard to read
| | | | | Joined: May 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 51 | Does the factory assembly manual have part numbers in it because I found the rear spring rear bracket number 3656668
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I could not find that part number in the Master Parts Catalog. I could not find a listing for the part, either. Maybe someone will try to look it up? | | | | | Joined: May 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 51 | I don't mind looking just don't know where to look
| | | | | Joined: Apr 2012 Posts: 35 New Guy | | New Guy Joined: Apr 2012 Posts: 35 | Take some measurements, how far it sticks out & how wide it is & I'll compare them to the ones on my 1 ton I have.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I don't think you will find anything that is riveted to the frame in a parts book. Dealers weren't equipped to do rivets so even 60 years ago it would have been a factory or a salvage yard item. I have only GMC. How big is a 4400? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 51 | 80 grit I'll take some measurements in the morning
Crenwelge 4400 is a 1 1/2 ton truck like a 2 ton
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have 1 ton and 2 ton AD trucks and best I can tell those hangers are the same, also same as 3/4,ton, and 1.5,ton. One on my 1 ton is worn, I have salvaged one from a 2 to. But yet to replace it. Should also be same part at all 4 corners of the rear springs, so lots of those hangers out there for the picking.
Hope that helps. | | | | | Joined: May 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 51 | Thank you grigg helps alot.
80 grit I came up with 5'' from frame outward,3 1/2''center to center top riviots,and 4'' from bottom of bracket to center of top riviot
| | | | | Joined: Apr 2012 Posts: 35 New Guy | | New Guy Joined: Apr 2012 Posts: 35 | Thank you grigg helps alot.
80 grit I came up with 5'' from frame outward,3 1/2''center to center top riviots,and 4'' from bottom of bracket to center of top riviot I just checked my 1 ton & the measurements match exactly.
| | | | | Joined: May 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 51 | Sweet thank you everyone for helping now I know what I'm looking for
