3 members (Rusted Nut, 68ironhead, 1 invisible),
88
Mod | | | Forums66 Topics128,093 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 16 New Guy | | New Guy Joined: Feb 2014 Posts: 16 | hi currently in the throws of purchaseing a 57 I tonner << couple of questions need answering << ??? its got the bigger trucks wheels presume they are 8 stud ?? question no 1 can I just fit 5 stud spindles of a 3100 straight on the front ?? or do I have to change the complete axle ?? diffs not a problem question no 2 if yes to the above question << wheres the best place to get some 2 inch drop spindles that will take original brakes ?? question no 3 is the any straight bolt in power steering units for original column 55 56 57 models ?? ok that's all for the mo !!!!!!!!!! everyone be good or be bad being good
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Jerryatric, First thing to confirm is the size of your truck. Your thread title says it's a 4400, but you are calling it a 1-ton. The 4400 is a 1-1/2 ton, a 3800 is a 1-ton. If it's a 4400 it will have the "big truck" front fenders and grille. The wheel openings will be about 42" wide at the botton of the fender. The fender will also have a larger flair than the 1-ton and smaller truck fenders. The only 4400 parts that are common to the 3100 are the Hood, inner fenders and Cab, that's it...the frame and suspension parts are way bigger (3100 vs 4400). Let us know what series truck you have so we can correctly answer your questions. Mike B  | | | | | Joined: Feb 2014 Posts: 16 New Guy | | New Guy Joined: Feb 2014 Posts: 16 | thanks mike b ok now you got me thinking << as im buying it blind and only had the 1 pic in which it didn't show flared guards at all ,,, it was listed as 1 ton 4400 flatbed dually which I checked the wheel opening in the pic I had against a lot of pics and it looked like they were the same as 3100 type ,, ??? anyway will 3100 guards fit it ?? cheers jerry ( atric ) | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Jerry, The 1/2 thru 1-ton trucks all share the same front clip. If it has the sharks mouth grille it's a 1-ton or smaller. You can see what a 4400 1-1/2 ton looks like on my web page (it's the brown truck)...click on the Mike's Garage link under my signature. Mike B  | | |
