2 members (Gdads51, 1 invisible), 92 guests, and 0 robots.
Topics128,052
Posts1,055,743
#1098531 04/20/2015 10:58 PM
V
V Offline
Does anyone have a comprehensive list of seal numbers? Unfortunately with the lack of customers service and skilled counter personnel at most parts stores today, I have had difficulty getting parts.
The 3800 tends to be a bit of an enigma as you well know.
So I was hoping someone might have a list of seal part numbers.
Thank you
Seals are one item that I find quite easy to get at the auto parts stores either by the numbers on the old seals or by the dimensions of the bore, shaft, and thickness.
Sometimes they can look it up by application but it is still smart to confirm dimensions.
What seals are you looking for?
1952 Chevrolet 3800 pickup
---All pictures---
V
V Offline
At the moment I am looking for the output seal for the 4 speed in my 48 3800. A few weeks ago I was looking for axle seals by application without pulling them.
3B Offline
Hy vermont48, welcome, the transmission output seal should be SKF p/n 22340 $11.66 at RockAuto, the rear wheel seals should be SKF p/n 28426 $7.63 at RockAuto, hope that helps.
V
V Offline
Hey! Thank you very much!
If you know your shaft size and Outside Diameter, you can go here.
http://www.timken.com/en-US/products/Documents/Seal-Specification-Guide.pdf
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Moderated by  Dusty53
