| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | I think it's time for a clutch...235 1957 engine BW10R trans with OD not hooked up. Is there anything I should tell the mechanic special to look for. Last clutch I did was in the seventies. Are there any superior plates...springs...machining that I should ask for? Any information I have to impart to the mechanic would help me and truck. Where is the best place to get parts FLAPS or Jim Carter. As always thanks for your time and advice.
Steve | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Contact superior clutch in San Jose.
2123 Bering Dr, San Jose, CA 95131 (408) 436-1101
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Thanks.....but the truck is in Grass Valley, CA. Can I just purchase the correct parts from them....thanks for your help | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | That's what I did. Call them to confirm.
