7 members (55shaker, dt235sd, Hanks custodian, NJC, 3B, Gdads51, 1 invisible),
211
Mod | | | Forums66 Topics128,086 Posts1,056,098 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 13 Junior Member | | Junior Member Joined: Oct 2003 Posts: 13 | I just bought a 52 chev PU which I was told was a 1/2 ton (I think). I can't find any markings on the truck anywhere that would indicated which model it is. Is the VIN my only way of finding out if it's a 1/2 ton or 3/4 ton. | | | | | Joined: May 2001 Posts: 31 Shop Shark | | Shop Shark Joined: May 2001 Posts: 31 | Half ton trucks came from the factory with six lug wheels, three quarter ton trucks came with eight lug wheels. Bed length is also an indicator; half ton Chevrolets had shorter pickup beds (roughly six feet). - AJ | | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Also, two stake pockets in front of the rear fender on either side of the bed will indicate a 3/4 ton. A two piece driveshaft is another characteristic of a 3/4 ton that is easy to check.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | What is your VIN number? Also, the 1/2 ton trucks gross vehicle weight (GVW) is 4,800 and the 3/4 ton trucks are 5,800. listed on the VIN tag on the drivers door post
| | | | | Joined: Oct 2003 Posts: 13 Junior Member | | Junior Member Joined: Oct 2003 Posts: 13 | Thanks everybody. Looks like it's a 3/4 ton. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I would ask for some of my money back if I could. Right now a 1/2 ton is worth more than a 3/4 ton. | | |
