5 members (CuzzFuzz, greenie-reddy, TexasA&M48Truck, Peggy M, 1955 1 Series), 48 guests, and 7 robots.
Topics128,012
Posts1,055,320
Members48,419
#1097740 04/16/2015 4:01 PM
I am trying to decide whether to have an automatic steering column or put a shifter on the floor. I have a 283 and a power glide transmission. I would rather have the shifter in the steering column so there is more room on the floor of the truck. But will the steering column shift a power glide transmission because I think that most of the automatics for trucks were 350's. Anyway I don't have the steering column ether that might be a hard one to find.
Are you looking for an original AT steering column from a 1960-66 truck? They are a little hard to find, but not impossible. Later model C10 truck steering columns will swap in pretty easily, but it all depends on whether you want it to look original or not. I'd recommend an Ididit or Flaming River column. They are safer than the older columns.
The Ididit or Flaming River column are a very expensive alternative. Better try and find an original first.
Yes, they are expensive. If you can find a used steering column with a collapsible shaft, then you have increased the safety for the driver. Plus a tilt column is nice too.
I would suggest you check with Rich Sisneros, I'll bet he has a good used column that would work.
Rich Sisneros is located in Crowley, Colorado:
email: rjsisneros@ria.net
phone 719 250-5057
When I was looking back in the winter, I found 2 different sources for used and functioning powerglide columns one was in Kansas City and the other in florida.
ESum
ESum #1098307 04/20/2015 12:33 AM
Proceed with caution if the Kansas City source is Tony Smith @ 4-5-6 Chevy trucks. I've had good luck buying from Tony, many more than a few others haven't.
That's why I suggested Rich Sisneros....
Ok... Rich Sisneros doesn't have one right now and Tony only sells re-built ones and he wants $400 for them.
Esum.... do you know how to get hold of the guy in Florida?
Riding in the Passing Lane
I answered your add in the parts wanted. We have one available in the K. C. area & are not connected to 4-5-6- Trucks.
George
1972 Chevy c10 Cheyenne Super
I will find it and try to post tomorrow.
ESum
Dennis' Chevy Truck Parts 727-541-2903
ESum
