8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible), 159 guests, and 1 robot.
Topics128,081
Posts1,055,955
Members48,430
#1098244 04/19/2015 6:11 PM
I put my heater in but I live in NC and don't have A/C in the truck. Since hot water will be running through the heater all the time I'm thinking I should install a cut off valve to keep extra heat out of the cab. Ideas/suggestions?
p.s. I've owned it for twelve years and it should be on the road in a couple of weeks!! Yippee
gerrys42 #1098300 04/20/2015 12:13 AM
Depends whether you want to be "original" or not. I wanted a valve I could operate from the cab so I installed a 4-seasons 74828 manually operated heater valve and a generic choke cable operator. The choke cable handle is visible under the dash but very few people recognize it as an add-on.
There was another thread a few month's ago discussing heater valves.
Harold Wilson
41 Chevy 3/4 Ton
Moderated by  ndkid275, Phak1
