| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | I put my heater in but I live in NC and don't have A/C in the truck. Since hot water will be running through the heater all the time I'm thinking I should install a cut off valve to keep extra heat out of the cab. Ideas/suggestions? Thanks p.s. I've owned it for twelve years and it should be on the road in a couple of weeks!! Yippee | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Depends whether you want to be "original" or not. I wanted a valve I could operate from the cab so I installed a 4-seasons 74828 manually operated heater valve and a generic choke cable operator. The choke cable handle is visible under the dash but very few people recognize it as an add-on.
There was another thread a few month's ago discussing heater valves.
Harold Wilson 41 Chevy 3/4 Ton
