| | | Forums66 Topics128,179 Posts1,057,162 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | I did a search and found some old post on various parts washer fluids. (It's funny how many of those fellas from 06 aren't around the bolt any more, I guess folks come and go. Anyway, what do you guys think? Know Deve uses Kerosene, but I remember dad always had Varsol for cleaning parts at home. I don't want anything that will explode, fumes will not cause cancer (always plan to use protective gloves), and with lighter density than oil, so I can drain the scum off the bottom after things settle out for a while. I don't remember it smelling like gojo, but I always liked the smell of gojo. I used a biodegradable water based one today, and had the biggest darn mess you'll ever see. These water based cleaners don't dilute or break down the hydrocarbons, so guess what the crud floats on top of the water. That's enough of that. Let's hear thoughts.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | This is a big question. It depends on what you are cleaning and what you are cleaning off of it. I have never found a need for a parts cleaner. Over rated. If I did have one I would use some kind of biodegradable soap/fluid. But a bucket of gas works for grease. Followed with Simple Green. If you can't use a bucket of gas without killing yourself you should eat with your fingers. I have a sand blaster where a parts cleaner would go. Better use of space.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | We use plain old vegetable cooking oil in our parts washer and it works fine.
I still use Varsol in my parts tumbler. It does a better job. When I get done I dump all of it in the used oil tank. In my part of Texas, used motor oil goes for bunker fuel, and once ships get out over open water, nobody cares what they burn. | | | | | Joined: Aug 2001 Posts: 3,616 Moderator | | Moderator Joined: Aug 2001 Posts: 3,616 | Bucket of gas is what I was raised on. Right next to the wood stove in a small garage while dad was pulling more parts. Don't laugh, this is really true. 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | If you can't use a bucket of gas without killing yourself you should eat with your fingers. Huh? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | To explain my joke: If you can't clean parts with gas safely, then maybe you should not handle sharp knives and pointy forks either. If it's not funny, it's serious.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2014 Posts: 218 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 218 |
I like using either diesel or #1 kerosene & if it's getting painted I rise w/paint thinner or mineral spirits..joe
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Oct 2012 Posts: 57 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 57 | i have 2 parts washers.. because of the high cost of good solvents anymore, i keep one full of diesel fuel and the other has denatured alcohol in it for things than need a second cleaner washing..i also have a blast cabinet and a pressured pot blaster for those rusty parts.. and sometimes with something large and real rusty i send them to the local monument place when they are blasting headstones
