3 members (klhansen, carbking, 1 invisible),
286
Mod | | | Forums66 Topics128,283 Posts1,058,521 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | Guys,
Please excuse all my questions as I'm new to old trucks. I removed my gauge cluster and was wondering how to remove the copper wire for the temp gauge? Oil pressure gauge looks to have a nut on it, but didn't see how the temp gauge releases.
And my final stupid question, can I still run the vehicle with these 2 lines no longer attached to the gauge cluster? Thanks again guys
1950 Chevy 3600 w/ 54 235 motor
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | You have to take the end of the tube out of the head on the engine and thread it through the firewall in order to remove the gauge set. The temp gauge tube is soldered into place on the back of the gauge.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If you can plug the holes on the motor where the tubes attached, you can run the engine.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | To expand on Roy's reply what you see isn't a "wire". It's a capillary tube. No electricity involved.
| | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | Be careful not to pinch or kink the tube from the engine to the temp gauge. Once the liquid inside escapes, the gauge will not work. There's a way to replace the sensor bulb with one from an aftermarket gauge, but it involves some pretty tricky cooling of the sensor bulb with dry ice and alcohol and some quick, accurate soldering to attach the new tubing and sensor bulb. I've got an original temp gauge head with a missing sensor bulb stashed away that I'm planning to do that with just to see if I can do it. If so, and it works right, I might start offering the service to forum members who have non-working temp gauges. Jerry
| | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | My only gripe with his procedure is the use of ice and salt as the cooling medium. Dry ice can be purchased at several places- - - -our local WalMart sells it. Its temperature is something like -70 degrees F., and when Methanol (shellac thinner) is used as the liquid, it does a lot better job of condensing the liquid in the sensing bulb. Be careful when handling dry ice- - -use heavy gloves or you'll get frostbite on your fingers. Jerry
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | My only gripe with his procedure is the use of ice and salt as the cooling medium. I agree with you, just passing along information. | | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | So if I were to replace the gauge unit would I need to buy a new capillary line for it? Being a complete newb with limited skills, certainly none involving grafting with dry ice...?
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | dx3,
If you purchase a new unit the capillary tube already comes attached to the gauge.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | Thank you Tim! I was looking at Classic Parts and they sell refurbished gauges. Wasn't sure if they came with them or not? And also if I have to remove mine for the core or if I just cut it off?
| | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | Well I called Classic today, and apparently the rebuilt are more expensive than new ones. I am looking at $550 for both gauges new (cheapest option). Really wasn't wanting to spend that kind of money on them, but I guess it will be good to know everything is operating properly between a new harness and new gauges.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Do you need to replace both gauges? What company is "Classic"? 1950 replacement oil pressure gauge: $60 (0-30 or 0-60) 1950 temp gauge: $60 Full 1950 complete mounted gauge set is under $300 Classic Parts of America (Truck Parts) | | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | I need both gauges (speedometer and other gauge) which was $550, at least that's as inexpensive as I could find it. And yes, that's the "Classic" I was talking about also. Did I miss the cheaper ones? Your link doesn't work for me, perhaps because I'm accessing it from my mobile phone. Do you need to replace both gauges? What company is "Classic"? 1950 replacement oil pressure gauge: $60 (0-30 or 0-60) 1950 temp gauge: $60 Full 1950 complete mounted gauge set is under $300 Classic Parts of America (Truck Parts)
| | | | | Joined: Dec 2014 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 69 | Tim - sorry I should have better explained. Unfortunately I need both. Neither of the 2 look to be in particularly good shape...
