| | | Forums66 Topics128,163 Posts1,057,044 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 40 Junior Member | | Junior Member Joined: May 2004 Posts: 40 | i started putting in 16 gauge( i think) metal for floor pans.......is this about right????....i am welding and riveting it in my 1950 panel front floor boards.........(back wood in the bed of the panel is in great shape)..any suggestions or advice on doing this is appreciated...thanks
1950 Chevy Panel 310
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | I bought a sheet of 14 ga to use as a replacement floor thinking it would be thick enough to support the seats and will run additional support bars/channel under the floor for more support. I may cut the floor out of another cab to use instead though. I have not decided yet. I think 16 ga can be used but you will have to run cross supports/channels underneath. If you space them correctly these can also anchor your seats. | | | | | Joined: May 2004 Posts: 40 Junior Member | | Junior Member Joined: May 2004 Posts: 40 | the only part of floorboard that is rusted is on each side off the gear shift( 4 speed).......i am buying the fiberglass hump section over the gear shift, i welded in 16 gauge last night and cut my 2 1/2" hole for brake fluid check over the master cyl....turned out real good......all i did was remove all old patches and weld in floor pans....
