1 members (Phak1),
186
Mod | | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10944 02/29/2004 2:13 AM | Joined: Sep 2002 Posts: 12 Member | | Member Joined: Sep 2002 Posts: 12 | hi does any one know if you can take a factory 56 4 speed trany and hook it up to a 327 motor its currently hooked to a straight six 235 or 261?? | | |
#10945 02/29/2004 2:44 AM | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | The transmission should be just fine. The bellhousings are not the same for the 6 and V8.
Rick | | |
#10946 02/29/2004 2:52 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yeah, like Rick sez, ya just need the bellhouse that goes w/ the V8, as the I6 bell won't fit the 327
Bill | | |
#10947 02/29/2004 4:09 AM | Joined: Sep 2002 Posts: 12 Member | | Member Joined: Sep 2002 Posts: 12 | thanks alot are the v-8 bellhousing for the 4 speed 56 stock 4 speed hard to find or will any small block standard bellhousing work. | | |
#10948 02/29/2004 4:25 AM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | mitch, This is a Chevy truck bellhousing like your looking for. Truck bellhousing on E-Bay
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
