| | | Forums66 Topics128,050 Posts1,055,684 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 26 | I have a 55 3100 five window. It is just the shell. I have removed the fenders, hood and bed. I wasnt planning on removing the cab. A friend said this is the best time to do it right and remove the cab to repair or replace the floor pan. I agree this would give me full access to the frame and do a clean prep of the frame. Is there any you-tube info about the steps in revoving the cab? The cab is in good condition just the usual rested corners. I would repace the floor pan if I removed the cab. This seems overwhelming please give me some relief advice and direction.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | There are lots of sites that have information thats helpful starting with this one. I have two projects that are documented that you could learn stuff from. You have come to the right place here. Lots of great people and help available. Good luck!
| | | | | Joined: Apr 2010 Posts: 123 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 123 | I was recently asking similar questions. Here is my thread that has some info on cab removal: Floor Board Replacement
Chuck
1950 Chevy 3100 Deluxe Cab A few Harleys and '76 Triumph Bonneville
