5 members (Brian Moore, Jims46, Sedgewick, walter74, J Lucas), 63 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#1094009 03/27/2015 3:11 AM
im installing the door window glass channel and its trying to buckle in the top corner of the rear of the door, it is a tight bend, has anyone had that problem. its from bowtie bits
jacksun #1094017 03/27/2015 3:26 AM
I roll the window all the way up to form it into place. Then I screw it into place with tiny self tapping screws, then I roll the window down, and work out the buckles with a blunt screw driver and my fingers. It will fight you if you try to work out the buckles prior to screwing down the channels.
Carl
52Carl #1094027 03/27/2015 4:29 AM
thanks . I will try that
