Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (VEW, mo2cyl, 2-Ton, Otto Skorzeny, Deegs53, 2 invisible), 610 guests, and 1 robot.
Topics126,781
Posts1,039,298
Members48,100
Most Online2,175
Jul 21st, 2025
#109380 03/22/2003 9:51 PM
There was a thread on here a while ago asking about welding new sections into a frame. The current issue of Custom Classic Trucks has an article where they shorten a frame 12" by removing a section. It is quite interesting and the cutting and welding is done on about a 45 degree angle.
1951 1 Ton Completed
#109381 03/22/2003 10:21 PM
It is best to do it at that angle as a butt-weld is not as strong unless you use a frame-glove(extra piece of frame to fit inside the original).Even then, it will add weight, a little but not much.
#109382 03/22/2003 10:38 PM
Mechainiac,
I was just mentioning the article and actually this is something I know very little about. They mentioned the frame glove (not by that name) butI don't think that described how to weld it in. Wher would you place the welds on the reinforcements? Would you stay away form the corners?
#109383 03/22/2003 11:06 PM
Junior Member
Junior Member
the best way if you have the room, to remove or add a section of frame is to make a cut that looks like a z. so you leave the top of one section and the bottom of the mating section. dont know if that makes any sense.*L*. that way there isnt one single line where all the stress lands its spread out over a larger area less likely to fail.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.076s Queries: 13 (0.072s) Memory: 0.6054 MB (Peak: 0.6429 MB) Data Comp: Zlib Server Time: 2025-09-22 21:47:02 UTC
Valid HTML 5 and Valid CSS
