| | | Forums66 Topics128,052 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 26 | Helping a friend who has two bare frames he wants to build. Both have the more modern tubular shock mounts which means they are 1950 or newer. The difference is the E-brake cross shaft and how the e-brake levers that pull the e-brake cables are mounted to the shaft. One has small teeth which allows you to orient the lever in two or three different positions on the cross shaft. The other has two flats which only allows one position for the lever. This second one was just purchased as a 1953 chassis. I'd like to find out when this change took place to give me a better idea of the year of the other chassis. | | |
