0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 136 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 136 | 1953 Chevy 3100.
I'm almost at the point where I need to remove the cab from the frame, but have a couple of questions.
All the sheet metal is good, it is a solid cab.
What is the best method to lift and move the cab without tweaking it?
To strip and paint the underside, is it best to flip the cab forward and let it rest on the firewall?
Doors on or off? I have not taken them off yet, but will need to at some point.
Thank You Tim
'53 3100 5-window '57 Mercury Monterey 2-Door Sedan Tim H
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | using the search function conveniently provided at the top of every page on this site I found this.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Oct 2013 Posts: 97 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 97 | Gus is right [regarding bigtonkas video] and that is what we did with my 46 cab ..... my wife, weakling me, and our 2 sons. It was very easy especially since everything had been stripped .... dash, doors, everything. On another post here on stovebolt someone recommended placing it on its' firewall as it would them be less likely to bend or damage anything. Placing it on the firewall to work on the bottom, that is. Otherwise mine sits upright on a homemade wooden dolly screwed to the wood so it won't slip around while working on it ..... so far so good - haven't gotten to the bottom yet.
Lane
sweetpealane
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | beer, a few nephews, and a few minutes. I made a cab cart as many others have so I can paint it off the frame, but if you want to just take it off and set it on the floor, take the doors off, get a few guys to help you, and just do it. It's fine to set it on the firewall. Without a cart, its the only way I would want to set it on the floor. http://devestechnet.com/Images/Restorations/1950B/D50b01021lg.jpg | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | I layed mine on its back on a mattress so that I could finish up welding the toe board to the floor board. No problems. Carl
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Never know when an old mattress will come in handy - don't want to give my wife any "doghouse" ideas though.
Deve - why didn't you attach it to your rotisserie? Would it be worth making a jig? 360 access and mobility..
Brad - How did you attach the 4x4's to your hoist without drilling a hole and weakening your hoist?
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Allen if only I could figure out a way to do that. There aren't alot of strong enough points on the cab in the right places. Thats why I went to all the trouble of making a Think Tank section of my website. So people could brainstorm such an idea.
Back in the day, at the factory, I think they sent them down the conveyor using the fender wells somehow, kind of how a fork lift with special lift ends would do it, but no evidence. Not much strength anywhere. | | |
