2 members (ronsway, Nick in Manitou), 108 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
I just installed a cigarette lighter & it's shorting out & blowing the 20 amp fuse. I hook power to the center post & attach ground to the stud on the outer case.It looks so simple.... What am I doing wrong?
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
I figured it out. The lighter was grounding out internally. Took it apart & reassembled & it works fine.
On a related issue, though, I don't plan to use the lighter but will hook up a GPS or charge my phone. 20 amps seems high for those purposes. Any suggestions?
Thanks.
~Denny
1953 Chevy 3100
I have mine fused at 10 amps and it works fine for the electronic stuff (we don't smoke so we don't need to use the lighter). The fuse is there to protect the wiring only, not the devices...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Cigg lighters in modern cars use 30 Amps, although 10/15 should be enough for most things if you won't use a lighter.
All devices working with a cigaret lighter socket have a small tube fuse directly connected to the spring loaded pin that makes contact with the positive side of the cigarette lighter.
Might be good to know in case one of your devices stop working but the fuse in your truck/car is intact!
Chevrolet 3100
Year: 1951
engine: inline 6 217CI
Transmission: Manual 3-Speed.
12Volt.
Sir Searchalot
Sir Searchalot
Thanks.
Check out an owners manual from a modern vehicle with a power point and see what size the fuse is.
If I were you I would make sure the "lighter" I used was just a false front for looks..... and disarm it so it could not possibly fire up.
Your fuse is there to protect the truck wiring...what size wire did you run to the lighter?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Thanks for the comments. I'm using 14 gauge wire to the lighter. Good idea to "disarm" the lighter as I don't plan to use it. I'm not quite sure how to do that but I'll check it out.
~Denny
1953 Chevy 3100
a booted connector at the lighter with help prevent direct short.
...example...
My lighter stopped working today, I don't know why. There is power so i can charge my phone and use other devices, but the lighter won't work. Its just an ordinary aftermarket "hotrod style" lighter. But it doesn't get warm at all. Any tips of how to fix them?
Chevrolet 3100
Year: 1951
12Volt.
Look at the element. That coil at the working end of the lighter. Is it broken? Is the center still sticking out? The most common reason for the lighter to quit is it is open. The element can be replaced. It will unscrew from the knob. new ones are easy to get from FLAPS and vendors. Crud at the bottom of the socket can also keep it from getting a good connection. Real simple thing and not too hard to work on. If the coil is broken it will have to be replaced.
Steve H
Thanks Steve, will take a look today!
Chevrolet 3100
Year: 1951
12Volt.
