2 members (RLB, Guitplayer), 139 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#1092340 03/19/2015 4:21 PM
I was wondering if anyone has ran this setup in a '53 GMC or if you have any input in converting to this: http://www.ecklerstrucks.com/chevy-truck-center-link-and-tie-rod-set-1947-1955-1st-series.html
The PO of my project ('53 GMC with '55-'57 chevy 235, 4 on the floor, and '70 4.11 rear end) put a rear drum on the front tire and it popped off and damaged the tie rod. It looks bent and I'm going to need at least the tie rod ends anyways. I appreciate any input.
I installed this set up on my 51 panel. I got it from CPP , but it looks the same to me. I installed power steering at the same time; along with disc brakes.
Very happy with it.
I installed the set from CPP in my '55, a year and a half ago. It was easy to install and tightened up the steering. Very happy with this set. My old tie rod looked like a snake. The one in the kit is 1" and is much better. Pics of the install in link below.
I have a CPP power steering kit and tie rod on order. Glad to hear all works well.
Thanks for the feedback!
