| | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 |
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Osborn, big bucks but they won't fly apart like the hardware store wheels and a good one will last for many many years. dg
Denny G Sandwich, IL
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I have had pretty good luck with Weiler for bench grinders. For hand held grinders I use Fein or Metabo. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just came in form the barn Ken, and happened to be looking for something and ran across a stack of wheels, got some Weiler wheels in there also. dg
| | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | Dosen't make any difference what brand name wheel you use always wear a shield or safety glasses when using one, even the best will spit a wire out every once in a while
You Learn more Listening than Talking
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | My forehead (fivehead, actually) concurs with the recommendation for the full face shield. I'm tired of my wife telling me, at the dinner table, to pull the wire out of my head. Carl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Luckily, I need reading glasses.
Luckily, I have safety-reading glasses that I use at all times in my garages or in my house-yard.
I have never had to pull wire out of my head (from my HF wire wheels), but I do not take chances with my eyes.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Out of my pants, out of my shirts, out of me coat, out of my hair. As mentioned earlier, even with the best grade of wire wheel the wires will fatigue and shed from time to time. But the cheap ones just pull out of the crimp and shed like a dog after a bath.
Had an itch one time in my Quadriceps femoris, that be the top of my leg above the knee. Bugged me for a couple of weeks. One day I was itching it and it snagged my finger. Put the 5x Opti-Visor on and saw a little silver something stick out of the skin. Grabbed it with my tweezers and believe it or not, pulled a 3/8" long curly wire out, I'd been walking around with it stuck in there for weeks. They'll get ya even through your Levi's. Had to check my pulse to make sure I was still alive cuz all it did was itch a little.
dg
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I had a 1"+ one go in my inner thigh all the way under the skin. Ended up going to the hospital and having it surgically removed. It was close to my fumer(sp) artery. With in 45 minutes of going to the hospital, they had me on the operating table and removing it.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I have never had to pull wire out of my head (from my HF wire wheels) That's a great success story, but those HF wire wheels are dangerous. Give it time, that wheel will make you have a bad day. I liked the price of them, too. Brad Wrench Fetcher, PhD | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do wear large bi-focal/reading safety glasses.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That first sentence I would agree with ya Brad. Every one of them, whether on a bench grinder or mandrel for a drill or grinder sheds from day one, and the more wires that pull out the looser the pack is and the worse they shed. The best way I know of to prove the point is to suggest spending fifty bucks on a Weiler or Osborn, big difference. I've got some of those that I've had on bench grinders for a decade and they're still holding together, a little smaller in diameter but still got all their hair. Like I said, they break from fatigue rather than shed. DG
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Although we still have wire wheels, for at least the last 10 years we use MBX blasters more than wire wheels. They have hook shaped bristles that really work. When they get dull, we turn them around and run them backwards on a whet stone. http://www.monti.de/en/The bristles come on carbon steel as well as stainless. The stainless is really nice to clean up before welding. We keep several of them around. One dedicated to carbon wire and the other to stainless wire. The rubber attachment works really well to remove decals to de-identify trucks. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Very interesting, Kenneth.
I wish I had seen that a few years ago. Well, we do have bed to cleanup . . .
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Will the Monti work on a bench grinder? Carl
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | It's obvious from many of you replies over the years Ken, that you connect with Germany for many things. I notice that you cater to a lot of their tools. Where are these sold here in the states, or do you have to get them shipped across the pond?? And same as Carl axed, do then make them to fit a bench grinder?
dg
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | A different perspective, recently used some Chinese made mandrel mounted disks bought at a car show. It seemed I was having to work the same area much longer than expected. I changed over to an older disk, bought years ago from, most likely a hardware store. Hey, I"m old and can't remember the source, cut an old coot some slack. Anywho, the old disk made short work of the effort. My best guess is the steel quality is different; one softer than the other. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I don't think Monti or MBX makes a wheel for a bench grinder. I have been to their factory, and it is a very small factory. We visit my wife's relatives in Germany 2 or 3 times a year. One of her relatives is a quality control engineer for Mercedes and I get tips from him. And her relatives have some her relatives have friends that are real gear heads. They are seriously into performance. 20 years ago I brought stuff along as checked luggage and fibbed a little when I came in through customs. Since all the names we grew up with have moved their production to China, I have lost interest in buying their junk. Apparently there are others who share the same sentiment. If you Google names like Knipex, Würth, Hazet, Stahlwille, Wera, MBX Blaster and Fein you will come up with a lot of US vendors that sell them. There are even a lot on eBay. I have a lot of Metabo tools, but the last sawzall I bought from them was also built in China. I have used Jancy Slugger magnetic drills for years. Fein bought them a couple of years ago. The last Slugger I bought had the Fein name on it and I think they have improved the quality of when Jancy was still an Iowa company. Once you use an Albrecht chuck in a drill, you will never want to see another Jacobs chuck. I found one for my Clausing drill press on US eBay for almost nothing.
I have even bought stuff on eBay.de and had it sent to relatives. Some of my wife's relatives are arriving at DFW tomorrow and will probably be here Thursday, but time got away from me and they are not bringing anything. | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Thanks for the information, Ken. So since they (probably) don't have a bench grinder wheel- which setup do you use the MBX wheels on?
Brad
Wrench Fetcher, PhD | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ahh, so that's your connection to the Vaterland, often wondered why you spend so much time over there, thought you might have business interests across the pond. Back when I was a contributing citizen and working at the lab, I had Albrecht chucks in my machinist cabinet. They were the first keyless chucks that I ever encountered. They're great, but I couldn't afford them for my shop after retirement and settled for a couple of Chinese copies from Shars. They're not to bad, a little sticky, but no where near as smooth as the Albrecht chucks. http://www.pbase.com/dennygraham/image/159541042dg
