| | | Forums66 Topics128,275 Posts1,058,439 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | I was wondering if anyone has ran this setup in a '53 GMC or if you have any input in converting to this: http://www.ecklerstrucks.com/chevy-truck-center-link-and-tie-rod-set-1947-1955-1st-series.htmlThe PO of my project ('53 GMC with '55-'57 chevy 235, 4 on the floor, and '70 4.11 rear end) put a rear drum on the front tire and it popped off and damaged the tie rod. It looks bent and I'm going to need at least the tie rod ends anyways. I appreciate any input. | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I installed this set up on my 51 panel. I got it from CPP , but it looks the same to me. I installed power steering at the same time; along with disc brakes.
Very happy with it. | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | I installed the set from CPP in my '55, a year and a half ago. It was easy to install and tightened up the steering. Very happy with this set. My old tie rod looked like a snake. The one in the kit is 1" and is much better. Pics of the install in link below.
| | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | I have a CPP power steering kit and tie rod on order. Glad to hear all works well.
| | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | | | |
