5 members (Jeff Ogden, Otto Skorzeny, KingG, Hotrod Lincoln, 1 invisible), 29 guests, and 5 robots.
Topics128,012
Posts1,055,316
Members48,419
#10919 02/21/2003 2:00 PM
I am getting ready to pull off the cab everything is disconnected but the steering column. What i need to know is can i disconnect it from the box ( if so are parts going to go every where) Or do i have to take the box off the frame.
47.5 Loadmaster 5 window
48 Chevy 3600
69 GTO convertible
#10920 02/21/2003 2:15 PM
You do not bother to say what year truck you are talking about, but if it is an AD, you need to unbolt the whole thing from the frame and snake it out. Cannot just remove the column from the box.
#10921 02/21/2003 3:06 PM
Sorry about that..... Its a 1948 3/4 ton. So i assume i have to unbolt the steering box and slide it out of the cab.
48 Chevy 3600
69 GTO convertible
#10922 02/21/2003 4:06 PM
Yup, what Brian said.
It works great as a two-man job--one inside the cab and one on the other end.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
