| | | Forums66 Topics128,067 Posts1,055,877 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | Hello,
I have a 41 chevy, special deluxe, with an original 216.
What exactly is needed to do a swap with a 235...i.e. new engine mounts, new flywheel, etc?
I just want to calculate the total cost of putting in a 235 and get it going, vs. the machine shop work that is needed to fix the 216.
Judson | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Stovebolt.com Tech Tip - "Swap that 216 for a 235 or bigger engine"
| | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | Well, I was going to swap for the 235 because Ive heard that is the easiest/smoothest fit.
Is there another engine that fits as easily?
If not, what is needed to swap the 216 with the 235? | | | | | Joined: Nov 2014 Posts: 623 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 623 | I think tclederman was directing you to the link above the quote, Judson. That's a really helpful article at that link. BTW, I've got a 235 and I like it.
"When I rest, I rust" 1951 3100 5 window w/ '56 235
| | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | | | |
