2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#109072 01/29/2002 4:37 PM
what grit of sand paper should I be sanding with to prep for spraying zero rust??? I'm preparing some metal that will be sanded down to metal, and then sprayed with zero rust.
May the force be with you - SoloWookie
solowookie.com
It says in the specs you don't want smooth metal. It needs some tooth for the Zero Rust to stick. I don't sand at all, wire brushing is all it needs.
Actually, even with wire brushing it is possible to polish (burnish) the metal and make it too smooth. It that happens, it should be roughed up once again before painting. I believe spec sheets for these products recommend hand wire brushing to avoid that.
54 3100 with 235
62 flatbed dump C60 with 261
thanks Tony... I think I'm gonna try the wire wheeld method with my new air compressor...... LOL I'll do the cancer spots, and the spots that need some body work first.
solowookie.com
