| | | Forums66 Topics128,264 Posts1,058,352 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | Are the bracket locations, and dimensions of the pickup and big truck running boards the same accept for the length? I may need to weld my rear half to the front of a short big truck running board as they are more readily available. Thanks Scott | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I don't know about the hole locations but with careful cutting and welding I chopped and channeled a standard size step down to fit my Toyota...(56 GMC bed on it) so I say as long as your going from large to small it's game on.
| | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | Actually I need to replace the front from the rear bracket forward but am not sure if that part is the same on the long and short running boards. Mine was bent really bad and I attempted to straighten it but it is not as good as I would like it to be. From the rear bracket back is good. Scott | | |
