2 members (VicZ, klhansen), 118 guests, and 3 robots.
Topics128,072
Posts1,055,904
Members48,429
Do they make lowering shackles or can I modify the stock ones for the rear for a 53 GMC 1/2 ton long bed. I already turned the rear leaves 180 degress and installed 3 in. lowering blocks but bottom plate under spring is real low to ground any ideas appreciated.
cuda, I think some have taken the front shackle mounts/brackets and used them on the rear. they are not as tall/closer to the frame.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
Mike just checked that out .looks like it may work;Thanks 4 tip
