1 members (dt235sd), 60 guests, and 1 robot.
Topics128,080
Posts1,055,956
Members48,430
#1089253 03/03/2015 9:18 PM
Hey folks
I need some help now.......
I have a 51 1/2T that I converted about 12yrs ago the front wheel/axles to the disc brake set up. I had a
wheel bearing failure that damaged just one of my front hubs
1 , Does anybody know what or where to buy just one 6 lug conversion wheel hub?
or as my memory is short....... is a factory stock hub used and the conversion kit added to that stock hub?
2 , Does anybody know the tapered wheel inner/outer bearing and seal replacement p/n’s ?
Jim & Caroline
Both the CPP kit and the POL kit I have installed use the stock hubs.
thx cletis
i placed an ad for those already
Jim & Caroline
