| | | Forums66 Topics128,019 Posts1,055,343 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 25 Member | | Member Joined: Jan 2002 Posts: 25 | Anyone know a site I can look at some paint chips? grcias J.D.Poole
It's what you learn after you know it all that counts.......
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | I don't know of any and there is good reason. The colors you would see on the monitor wouldn't be even close the color in real life. First off the chips are ink, so they are off to begin with. The colors represented in your monitor are a little off from what is on mine.
The paint companies are even starting to drop the old "paint chip" style books. They are trying to cut costs and have begun to use a "chip book" that is a poor color copy just like a magazine, without the "chips" that are glued on the page that we are accustomed to.
So, go daown to your paint store and look at the chips there. BUT, if you are going to "pick out" a color, I highly recommend to buy a pint and spray it out.
Or, pick out a color at a car lot and then take the color code off the car.
Those little chips in the book are not the same as seeing it on a car.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Jan 2002 Posts: 25 Member | | Member Joined: Jan 2002 Posts: 25 | well, I guess that does make more sense,thanks for taking your time.........J.D.Poole
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | You can look any where I've been with my 91 Chev. corsica. The paint is coming off in sheets. | | |
