5 members (walter74, baldeagle, BillCollins, Cosmo, Guitplayer), 107 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#1088605 03/01/2015 12:59 AM
Hi all, kind of new to these older trucks. I really enjoy driving the old girl around, but have a question about the electrical system. I got this from my brother, 1948 Chevy 6400 with a grain bed on it. He says he thinks it was converted to 12 volt at some time, and he had a regular 12 volt battery in it when I got it. My question is, how can I tell for sure? And if it is still 6 volt, will I harm anything with the 12 volt battery. Thanks for any help you can give me.
boonie #1088616 03/01/2015 1:35 AM
the only thing that would be important is if the generator is 6V [black tag] or 12V [red tag], a 6V generator won't charge a 12V battery - a 6V starter will work fine on 12V for years as long as you don't grind away with it for extended periods, light bulbs all need to be 12V of course, numbers will ID them, otherwise fire away
boonie #1088721 03/01/2015 3:27 PM
The voltage regulator will have a printed label that states 6 V or 12 V. It must match the generator. Usually printed right on the cover. They are wired the same way so it is easy to change out. Mounted the same way too.
Steve H
boonie #1088737 03/01/2015 5:14 PM
Riding in the Passing Lane
You can burn out the gas gauge if you put 12 volts in it without a resister.
1972 Chevy c10 Cheyenne Super
boonie #1089101 03/03/2015 1:17 AM
well, the gas gauge doesn't work anyway. we replaced the tank with a new one mounted on the frame several years ago, and my brother didn't figure he needed a gas gauge. I have a different opinion, and will probably be adding a gauge at some point.
boonie #1089228 03/03/2015 6:09 PM
From the Delco regulators that I have, the six volt ones have a long cover screw diagonally placed in two of the corners of the case. The twelve volt ones have a lower flange at each end on the cover with a short screw in the middle at each end.
1951 1 Ton Completed
boonie #1089265 03/03/2015 10:13 PM
Ya know Fred, I never noticed that before. I wonder if that
was standard throughout the industry?
Need to hear bout that from Dave or Jerry who taught it.
dg
Denny G
Sandwich, IL
boonie #1089438 03/04/2015 5:37 PM
I looked at my regulator, and I have screws approximately in the middle of the flange on each side, but they are not directly across from each other. Kind of offset. Provided Im looking at the correct piece. :/
boonie #1089441 03/04/2015 6:01 PM
I have seen 12v voltage regulators (and parts vendors sell 12v voltage regulators) that have their attachment holes in the 6v location (and have covers and cover attachment holes in the 6v location).
boonie #1089469 03/04/2015 8:23 PM
Tim,
were they made by Delco?
boonie #1089483 03/04/2015 10:48 PM
No - no manufacturer markings.
