1 members (baldeagle),
139
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 33 | Hi, wondering if anyone has used Clifford performance products in their inline 6. I am excited to get a boost in HP and torque and they have some great claims. Would be interested in anyone who added any type of performance parts and how they worked out. Thanks Kevin
Thanks, keep truckin!
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Many here and elsewhere think Clifford exaggerates their HP gain claims somewhat. Maybe a heavily modified engine might reach the gains they say in my opinion. That being said, I do and have used a Clifford 4 bbl intake on a pretty stock 235 and a softly modified 261. Without a dyno check, but seat of the pants, my truck(and formerly '55 car) had the feel of more torque. So you will see some performance improvement in most cases I think.
Drew
| | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Check out the cutaway of a 235 head featured on another thread. Putting a fancy intake and exhaust and multiple carbs on a head that can't flow enough volume to make much power is "lipstick on a pig!. Good eye candy, but it's a losing bet. http://s176.photobucket.com/user/curt160/media/848%20head/000_3183_zpsbb42b3bb.jpg.htmlI have a tendency to doubt the motives and the advertising claims of anyone who wants to solve all my problems by selling me something! Jerry
| | | | | Joined: Feb 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2015 Posts: 33 | I hear you but I would think an exhaust. Upgrade to headers would be an improvement?
| | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | The stock exhaust manifold will flow all the volume those tiny ports are able to produce. Does putting bigger links on one end or another of a chain make the whole chain stronger? The same principle applies to putting high-flow parts on either end of a restriction- - - -no net gain. Jerry
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | But there is that 6banger sound all of its own
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Yep, a split manifold will rattle windows a block away! A good set of steelpack mufflers helps if you really want to get obnoxious about it! Jerry
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | There's also the tuning aspect with a split manifold and multi carbs. Or there is the extreme approach like TJ's CHEVY. He went ballistic but with a 292. But in the end, it's your ride. Do what makes you happy. I have a completely unpractical motor and love it. Most mods for the inliners are pretty much window dressing.
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Anybody use the complete twin weber kit with headers from clifford? I realize its two 2barrels and intake matched with headers. Was looking for an intake and headers for my 270 anyways. just not sure if that is a good fit.
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Anybody use the complete twin weber kit with headers from clifford? I realize its two 2barrels and intake matched with headers. Was looking for an intake and headers for my 270 anyways. just not sure if that is a good fit.  Anybody have a performance intake??
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | How do you like that set up?Am looking at doing the same or Cliffords dual set up with headers.Was needing feedback
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Your setup- the Clifford 4barrel intake
| | | | | Joined: Jul 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 93 | I put a Clifford 4 barrel intake manifold on a 261 for a friend of mine with a MSD Atomic Fuel injection system. The manifold had 2 internal water leaks, so you might want to pressure test it before you install it. | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Jerry;
Does the same exhaust port issue apply to the "newer" 292 engines or just the "older" 235s?
Larry
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | it's a sweet ride. a 292 clifford intake, water heated, split 2 to 2 exhaust to a single walker muffler and single exh. LOADS of torque the thing is about doing any ONE thing you can't............... it's a combination of components that work together to make the whole system function. i'm not sure what you mean by this if you're asking will a 292 intake fit or is the same as a 235 the answer is yes. ALL inline 6's are the same length. the block are the same length, the 292 is 1.75'' taller. http://i67.photobucket.com/albums/h298/1951otter/22A-1.jpg
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | if you're asking will a 292 intake fit or is the same as a 235 the answer is yes. Say what? I don't think so. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | I have the twin weber setup on my 235 motor in my 46 1/2 ton, works great looks great | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | i have the dual weber 38 setup on my 235 in my 46 1/2 ton...i've also had my motor bored .30 over and had bigger valves installed in my 848 head with a bigger cam, certainly more power, but not like what they advertised........looks cool tho | | | | | Joined: Nov 2002 Posts: 2,783 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,783 | Check out the cutaway of a 235 head featured on another thread. Putting a fancy intake and exhaust and multiple carbs on a head that can't flow enough volume to make much power is "lipstick on a pig!. Good eye candy, but it's a losing bet. http://s176.photobucket.com/user/curt160/media/848%20head/000_3183_zpsbb42b3bb.jpg.htmlI have a tendency to doubt the motives and the advertising claims of anyone who wants to solve all my problems by selling me something! Jerry Jerry - how do you know lipstick on a sow is not appealing to a boar hog?  However, as to the increases, I agree completely. An engine is a system. Removing one bottle-neck from the system with multiple bottle-necks simply changes the location of the main system bottle-neck. Multiple carbs (when perfectly selected and synchronized) give a MODEST increase on an otherwise stock engine, not because of the increased air flow, but because of balance of the air/fuel mixture to all cylinders. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | I see lipstick on pigs with a sounder of piglets all around her in the Walmart all the time. Would she have been bred that many times without that lipstick? Hmmmm? I saw an original Corvette dual exhaust manifold at Carlisle for $950 this weekend. The only reason that I didn't buy it or at least offer a counter offer was because I have been listening to HRL too much. Now I don't know whether to thank him or cuss him. Carl
| | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | That Corvette manifold is one of the better ways to run dual exhausts, since it has a pretty conventional heat riser box and flap valve which will bolt up to a standard 1-carb intake manifold without all the exhaust heat problems the Fentons and other split exhausts have. However, the prices those original dual pipe manifolds bring these days is just short of legalized robbery. I think they could be bought over the counter at a Chevy parts department for less than $50.00 back in the 1950's! Jerry
| | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | That Corvette manifold is one of the better ways to run dual exhausts, since it has a pretty conventional heat riser box and flap valve which will bolt up to a standard 1-carb intake manifold without all the exhaust heat problems the Fentons and other split exhausts have. However, the prices those original dual pipe manifolds bring these days is just short of legalized robbery. I think they could be bought over the counter at a Chevy parts department for less than $50.00 back in the 1950's! Jerry Cuss him it is!
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I've been to the "gut" in Naples Italy, they put lipstick on more than pigs over there  Should we mention how Chevy engr's put THREE CARBS on 235's back in the day? I hang up and listen  Dave | | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | The Corvette 3-carb setup on the 235's only managed to gain 20-25 HP over the single carb engine, and it also used a more radical camshaft profile and 1/2 ratio higher compression. To get that HP gain, the top end speed went up a whole 200 RPM, from 4,000 to 4,200. The hottest Corvette 6 was the 1955 model, with 155 HP @ 4200 RPM, compared to the Powerglide-equipped passenger car engine at 136 HP, also rated at 4200. Earlier stovebolt 235's ran anywhere from 115 HP to 125 HP with a single Rochester 1-BBL carb. The slight increase in RPM underscores the problem with multi-carb/dual exhaust systems- - - -the cylinder head can't breathe well enough to take advantage of the extra CFM available.
Equipping a 235 with the extremely scarce and expensive OEM 3-carb, dual exhaust system these days would cost several thousand dollars, with only a modest power boost. Then there's the problem with even making that setup fit on a truck- - - -there's just no room for it! Jerry
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | When I built my 235 I used the same approach I learned in high school. Bored 60 over. Milled 848 head, intake & exhaust runners polished. One piece mechanical lifters (heavy but don't come apart). Patrick's 3/4 race cam. Stock intake and exhaust manifolds, with the Rochester one bbl. carburetor.
A good ear can detect the cam. The engine will turn 4,500+ rpm, and my old farm truck has seen 95 mph (stopwatch timed & paced, speedo doesn't go past 90) with 4.10 gears.
A classmate had a 48 two door. Had a 261 with the same head mods. and the full race cam for the 235. Carb was rejetted with drills, exhaust split with a welder. He could keep up with the city kids and their new V8s.
Fred 52 3600 69 C-10
