1 members (Otto Skorzeny),
52
0
Mod | | | Forums66 Topics128,092 Posts1,056,040 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Greetings- What are the bolts that secure a vise to the channels on a drill press table called? It looks like something specific would be made for this- almost like a carriage bolt- but I have just been using regular & irregular bolts & washers. I takes up a lot of time to shift the vise around the way I'm doing it, so I'd appreciate if somebody'd tell me what to go look for. Vise bolt channels Thanks! Brad Wrench Fetcher, PhD | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | They're called "T-slot nuts". Most machine shop supply places sell them. They can be used either with studs, nuts and washers, or bolts and washers from the top side. They're also used on milling machines, lathe face plates, and other workpiece mounting applications. Try checking here: www.victornet.comhttp://www.victornet.com/alphabetic/T-Slot-Nuts/791.htmlThese kits come with nuts, studs, and clamp blocks- - -easier and more versatile than using the slots in the vise base. http://www.victornet.com/alphabetic/Clamping-Kits/46.htmlI buy most of my machine shop supplies there. Jerry
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Thanks, Jerry! That helps a bunch. I just pulled them up on the Victor Machine link you posted...
I could really hit myself for not asking sooner- they'll make position changes a LOT easier.
Brad Wrench Fetcher, PhD | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | One item that's really handy is a Vise-Grip welding clamp with a T-slot nut built in. I've got to get a few of them soon! Jerry
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I returned a H.F. version of that tool three weeks ago- it just did not fit my table's 5/8" - 1 1/8" T-slot without sliding out.
The idea of the open-style welding clamp tool on the drill press table is great, though. It is easy to tell how well a 'vise grip' tool is made by checking the joint the lock nut mates with. Some look like they're soldered together with pot metal, as opposed to the solid-made (term?) older Vise-Grips way before Irwin got them. The HF one was *spoiler alert* not really that well made anyway.
Brad Wrench Fetcher, PhD | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | I'd suggest modifying a real Vise Grip brand tool by cutting off part of one side of the clamp and welding on a piece of rectangular stock the right size to fit the T slot accurately. Of course, I've always made specialty tools rather than paying outrageous amounts for work I can do myself. Most of my dedicated automatic transmission assembly/disassembly tools are home-brewed. Jerry
