1 members (baldeagle), 68 guests, and 1 robot.
Topics128,037
Posts1,055,467
Members48,424
Here is a little information I gleaned from a previous thread. Hopefully others will add to it. The link is a copy of a tech bulletin concerning partial engines that had provision for a full flow engine.
https://plus.google.com/10819770718...0762195122&oid=108197707187186692269
The following is the little information that I can find about the 261. Hopefully others will share more.
I think shop manuals remain silent on subjects like the dowels because it was not in the realm of Chevrolet dealers to do total rebuilds. 50 years ago there were hundreds of engine rebuilders around the country and GM considered them competition because they not only did the labor, but they installed aftermarket parts. GM wanted to sell now short blocks. And then there was another competitor of GM... the junk yards. Being a licensed salvage dealer for many years put me in that category. The Hollander states that casting No. 3759365 has the dowel. It clearly states that the doweled block fits all, but "Do not drive in the plug above the oil filter inlet hole. When driven in it is to be used with a full flow oil filter." The 261 was designed to be a truck engine, but the full flow setup just didn't work in trucks that were worked hard because of the rubber hoses under the exhaust became brittle from heat. 261 engines were very popular in their day with the guys that pulled cable dumps, but a lot of them bit the dust when they lost their oil.
Gas Pumper
Gas Pumper
You can see what I have so far here:
http://devestechnet.com/Home/TheVenerable261
I am awaiting two things to add to it, the compression numbers from Tim and the detailed instruction on how to properly drill the 848 head for the 6 water jacket holes. This how-to is to the credit of many people coming together. I got info from an article called The Forgotten 261, added some inliners.org info and lots of great stuff from some of you. If you would be so kind as to read it carefully, and then tell me how to make it more readable, more correct, and more complete, lots of people out there greatly appreciate it. When its complete, I will gladly share it here as well.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
The Hollander has pretty simple instructions for simple minded old junk yard dogs like me.
https://plus.google.com/108197707187186692269/posts?banner=pwa
Let me know if it works now.
Kenneth,
I had to request access to your album. It is not viewable.
I got in it. Lots of nice truck pics and info along with family.
Cute kid. Cute doggy. smile
Drew
I got in too - Thanks
